Page 2 of 27
FirstFirst 1 2 3 4 12 ... LastLast
Results 31 to 60 of 797
  1. @FoxRefire
    congratulations I haven't seen such a beautiful and important work in quite some time.
    I wanted to ask you are there any other services the non standard ones that use json sending is it possible to do something?
  2. Got it to work with your http://0.tcp.ap.ngrok.io:12365 api but not with http://127.0.0.1:18888
    (have note tested if the keys was alright yet)
    Edit: some sites just gives me "undefined"
  3. Search, Learn, Download! Karoolus's Avatar
    Oct 2022
    Belgium
    Originally Posted by kingkong0 View Post
    @FoxRefire
    You'll have to edit the WVServer code and compile it again
  4. Great, it works on cda.pl, player.pl but it doesn't work on canal+
  5. First of all thanks for the great work , loaded the server with the extension and this works like a charm !
    Just one last thing , for the pssh and the lic url do i have to select them manually every time or am i doing something wrong ?
    Regards
  6. Originally Posted by Karoolus View Post
    @FoxRefire
    thank you for the answer have you tried it yet and does it work?
  7. Search, Learn, Download! Karoolus's Avatar
    Oct 2022
    Belgium
    @FoxRefire
    I changed the code in popup.js to work with license servers like DRMToday, which uses json.
    I sent OP a code snippet, it's up to him whether or not to add it to his code.
  8. Originally Posted by Karoolus View Post
    @FoxRefire
    yes I wanted to see if it worked by making some changes and solving so when from undefined , yes I know it needs to be modified popup.js if it's not too much trouble you can say you put in popup.js
  9. Search, Learn, Download! Karoolus's Avatar
    Oct 2022
    Belgium
    let psshs = chrome.extension.getBackgroundPage().getPsshs();
    let requests = chrome.extension.getBackgroundPage().getRequests();
    let userInputs = {};
    function drawList(arr, _searchBox, _list, _userInputs) {
      const elements = arr;
      const searchBox = document.getElementById(_searchBox);
      const list = document.getElementById(_list);
      elements.forEach((element, index) => {
        const li = document.createElement("li");
        li.textContent = element;
        li.addEventListener("click", () => {
          userInputs[_userInputs] = index;
          document.getElementById(_userInputs).value = element;
          document.getElementById(_userInputs + "Index").value = index;
          document.getElementById("selectPssh").style.display = "none";
          document.getElementById("selectRequest").style.display = "none";
          document.getElementById("home").style.display = "block";
        list.appendChild(li);
      searchBox.addEventListener("input", (event) => {
        const searchValue = event.target.value.toLowerCase();
        list.innerHTML = "";
          if (element.toLowerCase().includes(searchValue)) {
    function selectPssh() {
      document.getElementById("home").style.display = "none";
      document.getElementById("selectPssh").style.display = "block";
    function selectRequest() {
      document.getElementById("selectRequest").style.display = "block";
    var CommonWV = async function (pssh, licUrl, _headers) {
      const serverAddr = "http://127.0.0.1:18888";
      console.group("fetch cert...");
      let certBuffer = await fetch(licUrl, {
        body: new Uint8Array([0x08, 0x04]),
        headers: _headers,
        method: "POST",
      }).then((resp) => resp.arrayBuffer());
      let certB64 = "";
      if (isValidJson(String.fromCharCode(...new Uint8Array(certBuffer)))) {
        let jsonData = JSON.parse(
        if (jsonData.license) {
          certB64 = jsonData.license;
        } else {
          console.log("JSON does not contain 'license'");
      } else {
        certB64 = btoa(String.fromCharCode(...new Uint8Array(certBuffer)));
      console.log(certB64);
      console.groupEnd();
      console.group("fetch challenge...");
      let jsonC = await fetch(serverAddr + "/getchallenge", {
        body: JSON.stringify({
          PSSH: pssh,
          CertBase64: certB64,
        headers: {
          "Content-Type": "application/json",
        method: "POST",
      }).then((resp) => resp.json());
      let challengeBase64 = jsonC.challengeBase64;
      console.log(challengeBase64);
      console.groupEnd();
      console.group("fetch license...");
      let licBuffer = await fetch(licUrl, {
        body: Uint8Array.from(atob(challengeBase64), (c) => c.charCodeAt(0)),
        headers: _headers,
        method: "POST",
      let licB64 = "";
      if (isValidJson(String.fromCharCode(...new Uint8Array(licBuffer)))) {
          licB64 = jsonData.license;
        } else {
      } else {
        licB64 = btoa(String.fromCharCode(...new Uint8Array(licBuffer)));
      console.log(licB64);
      console.groupEnd();
      console.group("get keys...");
      let jsonK = await fetch(serverAddr + "/getkeys", {
          PSSH: pssh,
          ChallengeBase64: challengeBase64,
          LicenseBase64: licB64,
        headers: {
        method: "POST",
      let keys = jsonK.keys;
      console.log(keys);
      console.groupEnd();
      return keys;
    function isValidJson(str) {
      try {
        JSON.parse(str);
        return true;
      } catch (e) {
        return false;
    async function guess() {
      endpoint = document.getElementById("guessr").value;
      const result = await CommonWV(
        psshs[userInputs["pssh"]],
        requests[userInputs["license"]]["url"],
        requests[userInputs["license"]]["headers"]
      document.getElementById("result").value = result;
    if (psshs.length != 0) {
      document.addEventListener("DOMContentLoaded", function () {
        document.getElementById("noEME").style.display = "none";
        document.getElementById("psshButton").addEventListener("click", selectPssh);
        document
          .getElementById("licenseButton")
          .addEventListener("click", selectRequest);
        document.getElementById("guess").addEventListener("click", guess);
        drawList(psshs, "psshSearch", "psshList", "pssh");
        drawList(
          requests.map((r) => r["url"]),
          "requestSearch",
          "requestList",
          "license"
    I might have edited other parts of this js as well, I'm not sure. I'm rewriting it to suit my own needs.
  10. Originally Posted by Karoolus View Post
        headers: _headers,
        method: "POST",
      let certB64 = "";
        } else {
      } else {
      console.groupEnd();
          PSSH: pssh,
        headers: {
        method: "POST",
      console.groupEnd();
        headers: _headers,
        method: "POST",
      let licB64 = "";
        } else {
      } else {
      console.groupEnd();
          PSSH: pssh,
        headers: {
        method: "POST",
      console.log(keys);
      console.groupEnd();
      return keys;
      try {
        JSON.parse(str);
        return true;
      } catch (e) {
        return false;
        document
        drawList(
          "requestSearch",
          "requestList",
          "license"
    thanks for sharing, a service like Canal+ using json from undefined, if it's not too much can I ask you which service you are testing on?
  11. Search, Learn, Download! Karoolus's Avatar
    Oct 2022
    Belgium
    I'm testing on platforms that use DRMToday. It might have a different json layout on your end. Check the output in the extension debug console and change the code accordingly.
  12. @Karoolus, can you get it to pull keys that has M3u8 links as well instead of just MPD? thanks
  13. Search, Learn, Download! Karoolus's Avatar
    Oct 2022
    Belgium
    I have no idea, what service is that on?
  14. multiple services has m3u8 with keys, I was just wandering is all. I like the app so far.
  15. Search, Learn, Download! Karoolus's Avatar
    Oct 2022
    Belgium
    Well none of the services I use, have m3u8 so that's why I asked. I can have a look if you tell me where to look
  16. no worries, I sent you a PM
  17. Ngrok public API shutdowned.
    Instead, I published permanent public API, use this instead.
    https://proposed-marketa-foxrefire.koyeb.app
  18. [Announcement]
    Released new version.please update extension
    New version includes:
    * Custom scheme support
    * Separate some codes to make code looks clear
    * Public API integration
    * Auto selects PSSH when there is one detected PSSH
  19. where we download the new extension?
  20. can you send me the URL again, as I looked on both links I had, but it says nothing been updated today. thanks
  21. thanks, going to try it out now.
  22. works good.
  23. @FoxRefire can you add to pull keys from m3u8 links that have keys as well? thanks
  24. Member
    Aug 2023
    Turkey
    waww working perfeckt thank you great work.,..
  25. Member
    Jul 2022
    israel
    Originally Posted by FoxRefire View Post
    https://github.com/FoxRefire/wvg
    Public API:
    This tool is researchment and pentest tool of Widevine, Do not decrypt content with keys obtained using this tool if yo do not own rights of content!
    The tool works great!
    Truly one of the most special things I've seen lately.
    Very smart development.
    I would recommend adding the following actions to :RESULT
    Direct link to the MPD file
    auto Code ready for download using N_m3u8dl-re or webdl.\
    Option to export the (cURL Header).
  26. This would be easier to use without the external WVCore server. Compile pywidevine to WASM using pyodide and it could all run in the extension...
  27. @FoxRefire
    first thanks for your rel
    anyway with latest version, i can run WVCore.Server.exe and win cmd open and close instantly
    before guesser does not work still for me, but WVCore.Server.exe cmd popup show some data correctly ...
  28. An interesting tool, but I still haven't moved forward with AM Prime.
